Extruder running too fast August 09, 2012 10:32AM |
Re: Extruder running too fast August 09, 2012 12:34PM |
Re: Extruder running too fast August 09, 2012 02:47PM |
Re: Extruder running too fast August 09, 2012 03:31PM |
Re: Extruder running too fast August 09, 2012 05:04PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Extruder running too fast August 09, 2012 05:44PM |
Re: Extruder running too fast August 11, 2012 11:13AM |
Polygonhell
The only other thing I can think of that would throw it off by a lot is if it was set to inches not mm either during calibration or during the print, look at the GCode you are running and make sure there is a G21 near the top and no G20.
Type G21 into pronterface then check it's extruding/retracting the correct amount.
But again that would be off by 25x not the 10 you seem to be seeing.
Sublime
6400 is definitely wrong unless you have a planetary geared extruder with 50:1 reduction. Did you calibrate so it moves 10mm of filament when the button is pressed? All modern slicers produce volumetric E values that are the length of filament going into the extruder not coming out.
Re: Extruder running too fast August 11, 2012 12:04PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Extruder running too fast August 13, 2012 10:38PM |
nophead
What happens if you type G1E1F200 in Pronterface? Does it feed 1mm or 10mm into the extruder?
nophead
What have you set the filament diameter to in Slic3r? If you set it to say 1mm and you have 3mm filament it would feed it about 10 times too fast.
Re: Extruder running too fast August 14, 2012 04:14AM |
Re: Extruder running too fast August 14, 2012 07:21AM |
Re: Extruder running too fast August 14, 2012 09:07PM |
Re: Extruder running too fast August 15, 2012 04:13AM |
Re: Extruder running too fast August 29, 2012 10:05PM |
