I already asked in slic3r issues list ( [
github.com]) if it could be possible to change a bit the cooling option for ABS
unfortunatly alex dismiss the question
but I have to go further and i will explain why
when you enable the cooling the fan is started at slow speed from the beginning for all the parts
whith ABS you get a furious amount of warp.
with ABS you only need to slow down for the small part and a bit of fan for the very small end part and bridge
How could you get that ?
I got the problem whith this part [
www.thingiverse.com]
whith the cheminey no cooling everything is allright except the upper part of the cheminey, with cooling a lot of warp
how to get the slowdovn only and the fan for the very small layer and bridge ?
I would like to have a check box to activate the fan for layer < xx sec
thank you
