I wanted to make a little keyring pendant for the daughter of a friend, and thought that designing a solid pendant and then only printig perimeters and a honeycomb infill with no top or bottom layers would look good. And it does, but...
Problem is: If I leave out the Horizontal Shells (by entering "0" at "Top" and "Bottom" Solid layers) then the infill of the first layer is out of scale. Looks like the fill density of the first layer is higher that for the rest...?
I made sure that the "Extrusion width" of the "First Layer" under "Advanced" and "First layer height" under "Layers and perimeters" are both set to "100%".
Is this a feature, did I forget to configure something or is it a bug?
Oh, and I'm using Slic3r 0.9.8
Edited 1 time(s). Last edit at 03/18/2013 04:39AM by Joghurt.
