0.9.9 uses a raft for support. Is there a way to disable it?
It works fine for most prints, however if there is say an overhang that is only 5mm above the print bed then the raft makes removal of the support very difficult.
Bob. That's not what I am talking about. In 0.9.9 if you use support, the support itself gets it's own raft. I want the option to have support on but no raft under the support. And yes the "raft" you point to is set to -0-.
