Slic3r adding extra move before retract causing blobs July 09, 2013 04:01AM |
G1 X87.448 Y83.330 E1.59741 ; the last move of the arc that makes up a hole I'm printing - head is at the 270ยบ point in the circle G1 X87.662 Y83.634 F12000.000 ; THIS IS THE PROBLEM LINE G1 F2700.000 E1.09741 ; retract G1 Z0.400 F12000.000 ; lift Z G92 E0 ; zero extrusion G1 X87.583 Y83.007 ; non-extruding move to the next area to print
Re: Slic3r adding extra move before retract causing blobs July 10, 2013 12:44AM |
Re: Slic3r adding extra move before retract causing blobs July 16, 2013 10:30PM |
Re: Slic3r adding extra move before retract causing blobs July 17, 2013 10:15PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Slic3r adding extra move before retract causing blobs July 18, 2013 01:52AM |
Re: Slic3r adding extra move before retract causing blobs July 18, 2013 10:13AM |
Re: Slic3r adding extra move before retract causing blobs July 27, 2013 03:11AM |
Re: Slic3r adding extra move before retract causing blobs July 29, 2013 06:10PM |
