Runnin Slic3r with perl 5.18 September 16, 2013 09:54AM |
Re: Runnin Slic3r with perl 5.18 October 04, 2013 09:02AM |
Re: Runnin Slic3r with perl 5.18 November 11, 2013 02:39PM |
Re: Runnin Slic3r with perl 5.18 November 13, 2013 04:08AM |
Re: Runnin Slic3r with perl 5.18 November 13, 2013 07:55AM |
Re: Runnin Slic3r with perl 5.18 November 14, 2013 01:54PM |
Re: Runnin Slic3r with perl 5.18 November 14, 2013 06:16PM |
00:12:35.358 : Perl API version v5.14.0 of Boost::Geometry::Utils does not match v5.18.0 at /usr/share/perl/5.18/XSLoader.pm line 92. 00:12:35.358 : Compilation failed in require at /opt/RepetierHost-0.90d/Slic3r/lib/Slic3r.pm line 32. 00:12:35.358 : BEGIN failed--compilation aborted at /opt/RepetierHost-0.90d/Slic3r/lib/Slic3r.pm line 32. 00:12:35.358 : Compilation failed in require at /opt/RepetierHost-0.90d/Slic3r/slic3r.pl line 13. 00:12:35.358 : BEGIN failed--compilation aborted at /opt/RepetierHost-0.90d/Slic3r/slic3r.pl line 13.
Can't locate Version/Requirements.pm in @INC (you may need to install the Version::Requirements module) (@INC contains: CODE(0x214d418) /home/fma/perl5/lib/perl5/i486-linux-gnu-thread-multi-64int /home/fma/perl5/lib/perl5/x86_64-linux-gnu-thread-multi /home/fma/perl5/lib/perl5 /etc/perl /usr/local/lib/perl/5.18.1 /usr/local/share/perl/5.18.1 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.18 /usr/share/perl/5.18 /usr/local/lib/site_perl .) at /home/fma/perl5/lib/perl5/CPAN/Meta/Prereqs.pm line 10.
$ cpanm Version::Requirements --> Working on Version::Requirements Fetching [www.cpan.org] ... OK Can't locate Version/Requirements.pm in @INC (you may need to install the Version::Requirements module) (@INC contains: CODE(0x12f08a0) /home/fma/perl5/lib/perl5/i486-linux-gnu-thread-multi-64int /home/fma/perl5/lib/perl5/x86_64-linux-gnu-thread-multi /home/fma/perl5/lib/perl5 /etc/perl /usr/local/lib/perl/5.18.1 /usr/local/share/perl/5.18.1 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.18 /usr/share/perl/5.18 /usr/local/lib/site_perl .) at /home/fma/perl5/lib/perl5/CPAN/Meta/Prereqs.pm line 10.
Re: Runnin Slic3r with perl 5.18 February 03, 2014 05:35PM |
fma
I'm unable to start Slic3r at all...
In fact, I can't even install perl deps anymore:
If I try to install Version::Requirements:
WTF???!!!????
Running Slic3r under Perl >= 5.16 is not supported nor recommended Not a HASH reference at /home/jc61990/Slic3r/lib/Slic3r/GUI/SimpleTab.pm line 74.
Argument "" isn't numeric in subroutine entry at /home/jc61990/Slic3r/lib/Slic3r/GUI/OptionsGroup.pm line 387.
Re: Runnin Slic3r with perl 5.18 August 27, 2014 12:35PM |
