Slic3r Never Finishes Generating Support Material December 18, 2013 02:59AM |
Re: Slic3r Never Finishes Generating Support Material December 22, 2013 12:25PM |
Re: Slic3r Never Finishes Generating Support Material December 22, 2013 03:56PM |
Re: Slic3r Never Finishes Generating Support Material December 22, 2013 06:37PM |
tmorris9
Default (-0-) is actually 45 degrees. You should never need support at a higher angle than that. Some machines can get away with lower numbers. I don't know though why Slic3r would hang.
Re: Slic3r Never Finishes Generating Support Material December 22, 2013 07:24PM |
Re: Slic3r Never Finishes Generating Support Material December 22, 2013 08:33PM |
I had it backwards, my fault. I meant to say the inverse and use KISSlicer as an example. When I hover over the Support Degree slider in KISSlicer, it says "any surface of the model more than X degrees off vertical will get support." I am assuming 0 off vertical is vertical and 90 off vertical is horizontal. Sorry again for the confusion. It seems inverse to me but I will need to do more testing with both programs to find out for sure.Quote
tmorris9
If you hover over the value window in Slic3r it states 90 = Vertical, so 0 would = Horizontal. So anything above 45 should not need support and some printers can even get away with 30 or less.
