z lifting after skirt?? January 13, 2014 03:38PM |
Re: z lifting after skirt?? January 13, 2014 05:10PM |
Re: z lifting after skirt?? January 13, 2014 05:27PM |
Re: z lifting after skirt?? January 13, 2014 10:35PM |
Re: z lifting after skirt?? January 15, 2014 04:56AM |
Re: z lifting after skirt?? January 15, 2014 05:58AM |
Re: z lifting after skirt?? January 15, 2014 06:16AM |
Re: z lifting after skirt?? January 15, 2014 06:47AM |
Re: z lifting after skirt?? January 15, 2014 01:21PM |
Re: z lifting after skirt?? January 15, 2014 01:33PM |
userzero
I'm new here, I found this forum while researching my problem.
I have the exact same problem, with support turned off, (for a part that doesn't need support) the skirt is on the first layer and the first layer of the part itself is on layer 2.
Also I have the other problem that was mentioned : on a part that needs support the support material is on the odd numbered layers, then the part material is on the even numbered layers.
Slic3r version is RC2,
lift Z is set to 0.
Re: z lifting after skirt?? January 15, 2014 05:42PM |
Re: z lifting after skirt?? January 15, 2014 05:44PM |
Re: z lifting after skirt?? January 16, 2014 02:30AM |
Re: z lifting after skirt?? January 16, 2014 04:01AM |
ashhhhh
Phew! Glad im not going crazy.
See the attached files.
Thanks.
Re: z lifting after skirt?? January 16, 2014 08:24AM |
justcurious
Upload your stl and exported config file at least for anyone to look into
Re: z lifting after skirt?? January 16, 2014 05:51PM |
Yep you are right.Quote
tmorris9
ashhhhh
Thanks.
That attached .ini is not the same as shown in your partial gcode list above it.
Here is the top of the gcode produced by your uploaded .ini file that shows settings
; layer_height = 0.2
; perimeters = 2
; top_solid_layers = 1
; bottom_solid_layers = 1
; fill_density = .2
; perimeter_speed = 20
; infill_speed = 20
; travel_speed = 75
; nozzle_diameter = 0.5
; filament_diameter = 3
; extrusion_multiplier = 1
; perimeters extrusion width = 0.50mm
; infill extrusion width = 1.02mm
; solid infill extrusion width = 0.85mm
; top infill extrusion width = 0.85mm
Re: z lifting after skirt?? January 16, 2014 05:55PM |
This is definitely the same problem, thanks for posting.Quote
userzero
justcurious
You're right. I'm sorry!
Last night I tried to slice a sample object with and without support and/or skirt in order to upload the required files. As I tried to replicate the problem Slic3r behaved rather erratically, I tried changing the parameters in the configure window and it wouldn't save the new config, even after trying repeatedly, I eventually found out that increasing a setting by only one increment would cause the software to not save the settings, So for example if I tried to set the skirt height from 1 to 0, it wouldn't save unless I first set the height to say 5, then save, then set to 0 then save again. Then I sliced the part and the skirt AND the first layer of the part appeared correctly on the first layer of the slice as it should. So now I can't replicate. I still have the problem with the support material showing on alternate layers though. I'll post my files on the thread about that specific problem tonight.
Just for background I am running Slic3r 1.0.RC2 from within Repetier, on a Dell 6510 laptop that can handle complex parts in Solidworks without any problems. I used to be able to print real good before, so I assumed the new version of Slic3r was the culprit.
Thanks for your time guys, sorry I wasn't smart enough to document the problem when it appeared.
Regards,
Georges
Re: z lifting after skirt?? February 04, 2014 01:20PM |
