Bug on 1.0.0RC3 two of three holes are closed by Slic3r --> solved with workaround March 13, 2014 04:07AM |
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r March 13, 2014 06:13AM |
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r March 13, 2014 02:00PM |
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r March 13, 2014 02:17PM |
CaJodo
Hey, you are a HERO. By changing Z-Rotation to 90 degrees, the problem is solved. I tried also 1 degree, this also solved my problem
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r --> solved with workaround March 14, 2014 12:20PM |
I agree with the above... and it's a fact !Quote
Sublime
That was the work around for a similar bug in version 0.7.2b which was fixed many many many many versions ago. I guess Slic3rs bugs never really go away they just go dormant for a few releases before being brought back with new bugs. When you get tired of the bugs I recommend Cura or Kisslicer or Skeinforge or Sfact
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r --> solved with workaround March 23, 2014 12:38AM |
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r --> solved with workaround March 28, 2014 05:54AM |
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r --> solved with workaround March 28, 2014 09:43AM |
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r --> solved with workaround April 04, 2014 05:30AM |
NO! you a wrong.Quote
Ralf
AFAIK nozzle diameter in Slic3r is only used to figure out extrusion widths.
So if you set your extrusion widths manually anyway, you should be good, if you just set set your nozzle diameter to 1mm.
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r --> solved with workaround April 04, 2014 10:43AM |
radus
Ralf
nozzle diameter used for calculate dimensions of model.
My cube is 10x10 mm.
If set nozzle diameter to 1mm then makes 0.5*diameter offset from edges of cube.
And if nozzle diameter be more than extrusion width my cube be smallest than 10x10 mm.
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r --> solved with workaround April 08, 2014 04:40PM |
radus
NO! you a wrong.
Re: Bug on 1.0.0RC3 two of three holes are closed by Slic3r --> solved with workaround April 28, 2014 06:55AM |
