100% infill? March 31, 2014 09:46PM |
Re: 100% infill? March 31, 2014 10:05PM |
camblonie
I'm trying to print a GoPro mount that is sturdy and I cant get enough infill at the main transition to the mount. Even when I make infill 1 its really more like 70" eye balling it. Is there some setting I've got clicked that i dont realize? Shouldnt 100% infill be solid?
Thanks
S
Re: 100% infill? April 01, 2014 08:42PM |
Re: 100% infill? April 01, 2014 11:31PM |
Re: 100% infill? April 02, 2014 05:47PM |
Re: 100% infill? April 03, 2014 04:08AM |
Re: 100% infill? April 03, 2014 07:53PM |
Re: 100% infill? April 04, 2014 04:57AM |
Re: 100% infill? April 04, 2014 09:55AM |
Re: 100% infill? April 04, 2014 07:39PM |
Re: 100% infill? April 04, 2014 10:54PM |
camblonie
Ok I'm starting to get frustrated now that i cant figure it out. I've attached a screenshot of the fill settings and the result in the middle of the print as shown in pronterface. The first and last layers look and actually print 100%. I'm expoting g-code, using Windows Vista, Slic3r 1.0.0. Same result on any STL. I appreciate all suggestions.
Re: 100% infill? April 04, 2014 11:25PM |
Re: 100% infill? April 05, 2014 01:50AM |
camblonie
Sorry for the confusion on the last post, I did play with the fill density at 70% but the pic shows it was clearly not near that. I attached one I ran at 1 and you can see the difference where the infill threshold is starting to affect the outer areas as they are separated from the main body.
Are you telling me that the print settings tab should have more options? I have been using Slic3r since 060. Maybe i have some old code in my ini?
Re: 100% infill? April 07, 2014 06:29PM |
Re: 100% infill? April 10, 2014 11:32PM |
