Help with customized start code needed July 19, 2014 11:44AM |
Re: Help with customized start code needed July 21, 2014 12:13AM |
Re: Help with customized start code needed July 21, 2014 10:17AM |
M42 S255 P28 ; Switch on gantry LEDs G1 Z200 X-45 Y 95 F12000 ; Move above block point M190 S[first_layer_bed_temperature] ; Pre-heat bed ...
Re: Help with customized start code needed July 22, 2014 06:45AM |
...... ; top infill extrusion width = 0.39mm ; first layer extrusion width = 0.73mm G21 ; set units to millimeters M107 M190 S75 ; wait for bed temperature to be reached M104 S212 ; set temperature G28 ; home all axes .......it came from Slic3r, my issue:
M42 S255 P004 ; Switch on heated bed PSUabove the G21 Command
Re: Help with customized start code needed July 22, 2014 09:40AM |
S[first_layer_bed_temperature] S[first_layer_temperature]
Re: Help with customized start code needed July 22, 2014 04:31PM |
Re: Help with customized start code needed July 22, 2014 05:24PM |
M42 P004 S255 ; Switch on PSU G4 P500 ; wait for "post" PSU M190 S[first_layer_bed_temperature] ; Use a substitution variable instead of explicit value!and set the first layer bed temperature setting in your "filament" tab to 75 then the code that is generated after slicing will be exactly as you describe.
