Slic3r-console: saving problem where value might be "yes" or "no"
September 06, 2014 06:56AM
Hi All.
Sorry for my English.
I have problem with slic3r-console.exe on Windows 8. I want to save config file with my params. Problem with values where need "yes" or "no". For example: I want to turn on cooling:
in cmd:
slic3r-console.exe --cooling yes --save config.ini
it works well. In config file value becomes equal 1. But when I want to turn off cooling:
slic3r-console.exe --cooling no --save config.ini
It doesn't work. In config value not changes. Why?
Slic3r version is 1.1.7 stable.
Edited 1 time(s). Last edit at 09/07/2014 05:24AM by Boomerang.
Re: Slic3r-console: saving problem where value might be "yes" or "no"
September 06, 2014 06:19PM
"config.exe"? Was that supposed to be "config.ini"?
September 07, 2014 03:57AM
DeepSOIC
Oh, sorry. Yes, config.ini.
Edited 1 time(s). Last edit at 09/07/2014 03:57AM by Boomerang.
September 10, 2014 04:53AM
No one had this problem?
September 11, 2014 10:34AM
Have you successfully saved with other settings changed? Is this specific to "yes/no" options? Is the file being written at all, or is there a chance that it is writing the config.ini to another location?
September 11, 2014 03:59PM
anXofY
Yes. Any settings with numeric value.
anXofY
No. I checked this many times. Other parameters are written succesfully. But parameter described above just leaves no changes.
For example, config contains parameter:
avoid_crossing_perimeters = 0
This command:
slic3r-console.exe --avoid_crossing_perimeters yes --save config.ini
works. Now config.ini contains:
avoid_crossing_perimeters = 1
slic3r-console.exe --avoid_crossing_perimeters no --save config.ini
not works. confused smiley
Config.ini still contains: avoid_crossing_perimeters = 1
September 15, 2014 09:51AM
With previous versions of Slic3r I found that settings sometimes did not "take" and I had to change them a few times (and sometimes together with other parameters). Try changing the setting as well as other related settings, saving, re-loading and if it has not "taken" change again and re-save. When it saves correctly change back the other settings you changed and re-save (then re-load to check). I sometimes had to fiddle several timers to get a good save.
Dave
