Thin walls with different thicknesses January 07, 2015 03:53PM |
Re: Thin walls with different thicknesses January 08, 2015 10:05AM |
Re: Thin walls with different thicknesses January 10, 2015 07:01AM |
Re: Thin walls with different thicknesses January 10, 2015 08:45AM |
rew
What happens if a wall is printed with a 0.4mm nozzle, but enough plastic is extruded for a 0.5mm wall? Won't the wall come out to be about 0.5mm?
Dave: KORYBA has already said that he has objects with many different sized thin walls, So changing a setting might make one wall come out right, but others will be wrong.
Re: Thin walls with different thicknesses January 10, 2015 09:49AM |
Re: Thin walls with different thicknesses January 10, 2015 02:17PM |
KORYBA
Hi everybody,
Thank you for your answers so far: Summing up I understand the following:
In theory it would be possible to slice (and print) thin walls with different thicknesses by calculating a variable extrusion width.
I assume that variable extrusion width will also have an impact printing quality.
However, in practice this is currently not possible in Slic3r!
Leo
