Slicer adding strange code to profiles March 06, 2015 07:01AM |
[rotate] degrees\n;scale = [scale]\n;skirt distance = [skirt_distance]mm\n;skirt height = [skirt_height]mm\n;solid fill pattern = [solid_fill_pattern]\n;solid infill below area = [solid_infill_below_area]mm (sq)\n;solid infill every n layers = [solid_infill_every_layers]\n;\n;\n;- – - – - – - – - – - – - – - – - – - – - – - – -\n;\n;\nT0; set primary extruder\nM73 P0; enable show build progress~~
[support_material_extrusion_width]mm\n;\n;\n;- – - – SUPPORT – - – -\n;\n;raft layers = [raft_layers]\n;brim width = [brim_width]mm\n;support material = [support_material]\n;support material threshold = [support_material_threshold]
Re: Slicer adding strange code to profiles March 06, 2015 05:30PM |
Re: Slicer adding strange code to profiles March 06, 2015 07:45PM |
Re: Slicer adding strange code to profiles March 07, 2015 03:06AM |
Re: Slicer adding strange code to profiles March 07, 2015 07:06AM |
Re: Slicer adding strange code to profiles March 08, 2015 05:34PM |
