Model position on bed March 28, 2015 10:35AM |
T0 ;set primary extruder M73 P0 ;enable show build progress M109 S[first_layer_bed_temperature] T0 ;heat bed up to first layer temperature M104 S[first_layer_temperature_0] T0 ;set nozzle heater to first layer temperature M103 ;disable RPM G21 ;set units to mm G162 X Y F6000 ;home XY axes maximum G161 Z F9000 ;home Z axis minimum G92 Z0 ;set Z to 0 M132 X Y Z A B ;Recall stored home offsets G90 ;set positioning to absolute G1 Z30 ;move Z to waiting height G1 X-95 Y-73 Z30 F14000 ;move to waiting position (front left corner of print bed) G130 X0 Y0 A0 B0 ;set stepper motor vref to lower value while heating M6 T0 ;wait for bed and extruder to heat up G130 X127 Y127 A127 B127 ;set stepper motor vref to defaults M108 T0 R3 ;set extruder speed G92 E0 ;set E to 0 G90 ;use absolute coordinates M320 ;acceleration enabled for all commands that follow G1 Z[first_layer_height] F6000.000 ;move to first layer height G1 X100 Y-73 F14000.000 ;move to front right corner of bed G1 X-90 Y-73 E24 F2000.000 ;extrude a line of filament across the front edge of the bed G4 P2000 ;wait for ooze to slow G1 Z0 F6000.000 ;lower nozzle height to 0 G1 X-95 ;wipe nozzle G1 Z[first_layer_height] F6000.000 ;set nozzle to first layer height G1 F12000 ;ensure fast travel to first print move G92 E0 ;set E to 0 again M73 P0 ;reset build progress to 0
Re: Model position on bed March 28, 2015 01:38PM |
Re: Model position on bed March 28, 2015 02:04PM |
turbo2ltr
I will say slic3r 1.2.6 is definitely unstable. It crashes quite often. I probably should have gone with the stable version for a newbie.
Re: Model position on bed March 28, 2015 02:46PM |
Re: Model position on bed March 28, 2015 02:55PM |
