solid infill over extrusion July 09, 2015 09:03AM |
Re: solid infill over extrusion July 09, 2015 02:17PM |
Re: solid infill over extrusion July 09, 2015 02:26PM |
Re: solid infill over extrusion July 09, 2015 11:57PM |
Re: solid infill over extrusion July 11, 2015 08:53PM |
Re: solid infill over extrusion July 13, 2015 07:34AM |
n2Jesus
ok, I tried your suggestions with no joy. I know it's not bad advice, it's me.
in my first post I mentioned adjusting the x/y movement speed. I did this because slic3r's default speeds were way too high for my printer (it's homemade) and I hadn't changed them. so, I reasoned that slic3r was allotting feed for that faster feed rate, but my printer couldn't move fast enough to lay it down properly.
Re: solid infill over extrusion July 13, 2015 05:02PM |
Re: solid infill over extrusion August 02, 2015 01:06AM |
Re: solid infill over extrusion August 03, 2015 02:43PM |
RRuser
"The other thing to ensure is that Slic3r and your printer are both using the same extruder reference - i.e. either absolute or relative extruder commands."
Where might this reference be set?
