Slic3r support problem
Posted by x306xcptnkirk
July 23, 2015 02:00PM
I've designed a printer mount for an Otterbox but I'm having problems with slicing and printing. Slicing yields the object to project the bottom mount all the way to the top completely filled and not just support, is there a setting to fix that? I'm not sure if I'm explaining this good enough but the top hole there should be an identical one on the bottom but the program infilled it the same as the rest of the object. Supports on other parts of it worked correctly. And it just infilled funny between those holes.
Edited 1 time(s). Last edit at 07/23/2015 02:24PM by x306xcptnkirk.
open | download - image.jpg (110.7 KB)
Re: Slic3r support problem
July 23, 2015 07:35PM
Slicer seems to do it with any support, if it's on the model surface it just extrudes the model. Is this common with 1.2.9?
August 06, 2015 10:02AM
How solid was this support?
