Strange printing pattern.
October 03, 2015 04:22PM
Does anyone know what this strange printing pattern on the right is and what causes it? I'm printing PLA, 65deg print bed temp for first layer, and 205 nozzle temp.
open | download - Print Pattern.jpg (423 KB)
Re: Strange printing pattern.
October 03, 2015 05:45PM
What type of printer was it printed on?
October 03, 2015 11:17PM
dc42
It is a kossel 2020 delta printer.
dc42
October 04, 2015 01:52AM
It's under-extruded on the right.
October 04, 2015 03:56AM
I thought it might be a delta, that's why I asked. Here are some possible causes:
1. Step size too large, leading to poor vertical resolution. Make sure you have at least 16x microstepping. Your steps/mm should be at least 80.
2. Motor currents too low resulting in too little torque and inaccurate positioning.
3. Delta segmentation. To reduce it, you can reduce the printing speed or increase the segments/second in the firmware config. Or use an electronics and firmware combo that does delta movement without using segmentation.
