Script to turn bed off 10 mins prior to finished print
December 15, 2015 08:48PM
Looking for help making a script that turns the heat bed off aprox. 10 mins before the print finishes. That way I can easily pop it off the bed. If unable to do this based off of time then turning the bed off at a certain layer could work as well. Maybe this is a setting somewhere that I overlooked? Any help would be greatly appreciated.
Re: Script to turn bed off 10 mins prior to finished print
December 15, 2015 09:19PM
Part of me wants to say "what's the rush?" Another part of me want's to say: "hmmm, interesting problem".
Tonight the first part wins...
I don't know, manually edit the gcode and insert an M140 S0 command near the end of the file...
Edited 1 time(s). Last edit at 12/15/2015 10:38PM by the_digital_dentist.
December 15, 2015 09:38PM
After reading through a lot of the posts looks like what is needed is conditional statements implemented in the Custom G-Code section. ex: IF [layer_num] == XXX THEN M140 S0
However until that is implemented looks like I will be doing it manually like the_digital_dentist suggested.
December 16, 2015 05:40AM
I am tempted to add this facility to RepRapFirmware, because at the end of a print, my heated bed takes about 20 minutes to cool down sufficiently for me to release the print from the PEI sheet.
My current solution is to use a float glass print bed (with PEI on top) clipped to the aluminium bed plate. When the print finishes, I unclip the glass and stand it vertically in a plate rack, so that it cools down much faster. If the print won't release easily, I put it in the fridge. Meanwhile, if I want to start another print immediately, I put another glass plate on the bed plate.
December 16, 2015 11:58AM
One issue is that if you turn off the heat a bit too early, the print may detach before it has completed - thus ruining maybe a 5 hour print job and wasting filament for the sake of saving 20 minutes.
If I'm in a hurry I just take off the plate and put it under a running tap ...
Dave
December 21, 2015 07:47AM
I thought that swappable glass plates (using thermal silicone pads for ease) was the fix for all this.
I learned that cooling to fast can chip the glass, so I just let it cool room temp.
December 21, 2015 07:54PM
Maybe the problem isn't killing heat before the print finishes, but speeding up the cooling process. It would be easy to add custom gcode to the end of a file to switch on fans that blow room temp air across the bed after the print has finished.
December 21, 2015 10:52PM
Maybe some larger fans you turn on when the print is done to cool the print bed faster.
