Slic3r 16 colors
March 02, 2016 04:00AM
I'm trying to do some experiment with 16 colors. It looks like from Slic3r is not possible to assign 16 different extruders (but maybe I don't know very well the sw).
So to do that I need to load on Slic3r all the 16 parts, put together, than export the assbly to amf.
Load the assembly .amf to Repetier-host , assign at every subpart a different extruder (here I can have 16 extruders) and the from Repetier-host run Slic3r.
It is a very long process, Is there a way to assign 16 extruders directly from Slic3r?
What I want to do is print with 16 colors the Benchy Boat [www.thingiverse.com]
Another problem I have it that the part "3DBenchy_-_Multi-part_-_Single_-_Hull_-_3DBenchy.com.stl" for Slic3r it's not a manifold object. All the other slicing sw I tested (Cura, Kisslicer) don't have any problem with this part. very strange....
Edited 2 time(s). Last edit at 03/02/2016 04:08AM by MikeB69.
Re: Slic3r 16 colors
March 02, 2016 07:20AM
Good grief! Do you have a photograph of your 16 filament printer?
Dave
March 02, 2016 09:02AM
Not yet. I'm finishing the "upgrade" . I projected the HOTEND and I'm waiting that the supplier will build it. See the prototype in ABS.
But this is a 4 filament extruder printer. I will mix the Cyano , Magenta and Yellow + Black or White to have the other colors.
The 16 extruders in Slic3r , are 16 virtual extruders. You can print with virtual extruder using repetier fw.
Here instead, you can see my printer doing some other "experiment" with a "parallel Printing"
open | download - HotFlux_02.JPG (381.6 KB)
March 02, 2016 06:30PM
What leads you to believe you can't configure 16 tools? I just tried turning number of extruders up to 128 and it didn't seem to be having any difficulty.
March 03, 2016 08:36AM
Yes. I'm able to create 16 Extruders, but after I cananot assigne more than 5.
See image 1 for the 16 extruders.
See image 2 where I try to assigne at each part a different Extruder. I can choose only 1 to 4.
Maybe this is the wrong way to do ... Is there a correct way to manage 16 extruders?
open | download - Slic3r_16Extr.JPG (107 KB)
open | download - Slic3r_16Extr_02.JPG (89.5 KB)
October 23, 2016 12:59PM
@MikeB69 Just type them in manually with your keyboard instead of using the dropdown menu. smiling smiley
Edited 2 time(s). Last edit at 10/23/2016 01:14PM by heinz.
November 22, 2016 12:03PM
Is there a way to rename all those virtual extruders? I guess, calling them "pink", "sunraise_red" or whatever, would make assigning them easier.
March 29, 2017 11:59AM
Nevermind!
Edited 2 time(s). Last edit at 03/29/2017 02:28PM by Eddiie.
March 29, 2017 12:54PM
No, I have printed a 12 color vase using this method.
How many extruders are defined in your Printer_settings?
Edited 1 time(s). Last edit at 03/29/2017 12:55PM by o_lampe.
