Infill density change when changing layer thickness May 24, 2016 06:44AM |
Re: Infill density change when changing layer thickness May 24, 2016 10:10AM |
Re: Infill density change when changing layer thickness May 24, 2016 11:43AM |
Re: Infill density change when changing layer thickness May 24, 2016 01:33PM |
Re: Infill density change when changing layer thickness May 25, 2016 09:26AM |
Chipmunk
@ Mikk36: The extrusion width for infill is zero
@Dmould: That is not logical, as a thinner layer should result in less material deposited per layer - 0.1 mm should deposit half as much material than 0.2 mm per layer
Otherwise the width of the deposited filament would be doubled for half the layer hight which would result in incorrect dimensions.
Chipmunk
Re: Infill density change when changing layer thickness June 02, 2016 05:38AM |
Re: Infill density change when changing layer thickness June 02, 2016 07:50AM |
Re: Infill density change when changing layer thickness June 03, 2016 03:53AM |
Re: Infill density change when changing layer thickness June 03, 2016 08:01AM |
Chipmunk
Because, where I get a nice raster for e.g. 10% infill at 0.2mm layer height, the raster degenerates to just one line when setting the height to 0.05mm and gets near solid when setting 0.4mm height.
At least the preview displays it this way.
Chipmunk
Re: Infill density change when changing layer thickness June 03, 2016 12:48PM |
Re: Infill density change when changing layer thickness June 03, 2016 01:01PM |
Re: Infill density change when changing layer thickness June 03, 2016 02:00PM |
Re: Infill density change when changing layer thickness June 06, 2016 07:55AM |
