First layer backward move drags back printed line June 22, 2016 03:56PM |
Re: First layer backward move drags back printed line June 23, 2016 07:21AM |
Re: First layer backward move drags back printed line June 23, 2016 02:03PM |
dmould
Your root problem is insufficient bed adhesion rather than the print path. Possible solutions are to increase bed temperature for 1st layer, increase 1st layer height but decrease Z zero height slightly to "squish" the plastic against the bed, or use a better bed material. Coating the bed with an ABS/acetone solution or solvent cement (as used to join plastic pipes) works well for me.
Dave
Re: First layer backward move drags back printed line June 24, 2016 07:08AM |
Re: First layer backward move drags back printed line June 24, 2016 12:57PM |
Hey, it worked pretty well, the first layer was laid down nicely. Also I have increased extruder temp for the first layer a bit.Quote
dmould
It results in a "lip" around the edges of the base of the print, but in most cases this is easily filed off afterwards.
