G-Code settings
July 12, 2016 01:41PM
Hello everyone!
I'm trying to print some lines and I'm using Slic3r to generate the G-Code. Slic3r makes automaticly this routine with aditional lines (RED) between the lines that I want to print (BLACK), how can I delete them? Which are the parameters that I should change in the settings?
Thanks in advance!!!
Edited 1 time(s). Last edit at 07/12/2016 01:42PM by jessmupo.
open | download - lineas.png (20.8 KB)
open | download - slicer lineas.png (91.1 KB)
Re: G-Code settings
July 12, 2016 02:38PM
lineas.png: The red is most likely showing how it's going to move between the black line objects.
slicer lineas.png: In slic3r on the preview or layers tab, the red in the object is infill.
Re: G-Code settings
July 13, 2016 05:17AM
Thanks for tour answer!
My printer prints these movements lines, is there any way to delete it?
Re: G-Code settings
July 13, 2016 05:53AM
Then your firmware is doing something wrong. It should not extrude anything if it isn't commanded to (with the E parameter).
Re: G-Code settings
July 13, 2016 09:28AM
What is the extrusion width, and what is the width of the lines in the STL?
It looks like the red lines may be infill - e.g if you are printing lines that are 1,5mm wide using an extrusion width of 0.5mm, it must print 3 lines side-by-side to make the 1.5mm width.
Make your STL lines thinner, or increase the extrusion width in Slic3r ("Print Settings">"Advanced">various extrusion widths).
Dave
