Welcome!
Log In
Create A New Profile
Home
Software Folder
Slic3r
> Topic
Cylinder inside a cylinder
Posted by
skinnybottom
Forum List
Message List
New Topic
skinnybottom
March 21, 2017 04:54PM
Hi
I am trying to print an open cylinder inside another open cylinder. When I try to slice with Slic3r I get an infill between the two cylinders. Can some one please help me to avoid this.
Thanks
Aaron
Reply
IMBoring25
Re: Cylinder inside a cylinder
March 22, 2017 01:22AM
Do you have them in a single STL or are you loading two STLs? Are the STLs showing as manifold in the status bar?
Reply
skinnybottom
March 22, 2017 04:33PM
Thanks for your reply
Yes it is manifold and it is one stl file. The two cylinders are connected at bottom, the walls are very thin
Reply
o_lampe
March 23, 2017 03:59AM
Do you run slic3r in expert mode? Did you check the "detect thin walls" box?
Reply
Dancer
March 23, 2017 04:22AM
We might be able to help you, if you provide us your stl-file :-)
Reply
Newer Topic
Older Topic
Print View
RSS
