Success: Dremel IdeaBuilder 3D20 with slic3r under Linux August 30, 2017 09:46AM |
M104 S[first_layer_temperature] ; switch on temperature (slic3r) G28 ; home all axes G1 Z5 F5000 ; lift nozzle M6 T0 ; auto-feed? (dremel) M106 ; switch on fan (dremel) M108 T0 ; set extruder speed (dremel) M109 S[first_layer_temperature] ; wait for temperature M116 ; wait for all temperatures (unused, but just to be sure)
M107 ; switch off fan M104 S0 ; turn off temperature G1 Z140 F3300 ; lower table G28 X0 Y0 ; home X and Y M18 ; disable steppers M84 ; disable motors (slic3r)
Re: Success: Dremel IdeaBuilder 3D20 with slic3r under Linux September 03, 2017 05:28PM |
Not just useful, I think it's awesome!!!Quote
I hope you may find this useful
Re: Success: Dremel IdeaBuilder 3D20 with slic3r under Linux October 09, 2017 06:00PM |
Re: Success: Dremel IdeaBuilder 3D20 with slic3r under Linux November 05, 2017 07:55PM |
Re: Success: Dremel IdeaBuilder 3D20 with slic3r under Linux November 06, 2017 08:16AM |
Re: Success: Dremel IdeaBuilder 3D20 with slic3r under Linux September 29, 2018 05:31PM |
Re: Success: Dremel IdeaBuilder 3D20 with slic3r under Linux October 10, 2018 07:17PM |
strelock
Does anyone have the script? It goes to a 404 error! I'd really love to use slic3r instead of Cura! I've found that many times when I can't get something to print or adhere to the bed after slicing in Cura using slic3r instead almost always solves the issue!
Re: Success: Dremel IdeaBuilder 3D20 with slic3r under Linux October 11, 2018 12:23AM |
Re: Success: Dremel IdeaBuilder 3D20 with slic3r under Linux October 12, 2018 12:10AM |
