Hi, total Noob here - Ender 3 + Slic3r 1.3.0
I just can't seem to get the sequential print function working...
I've got 'complete individual objects' ticked under 'Print Settings / Output Options' ; Extruder Clearance Radius 40mm Height 30mm.
I've gone into the Object settings and set 'Sequential Printing Priority' numbers for each part.... but to no avail.
This is not working for my actual components which are 65mm W, 12mm D 20mm H but also won't work for test objects of 10mm W x 10mm D x 5mm H
In both cases for the purposes of testing I have only 2 components on the bed and separated by 100mm.
I'm hoping there is something blindingly obvious I must have missed..!
Any help / suggestions gratefully received!
Many thanks
Zip
Edited 1 time(s). Last edit at 05/03/2019 03:16AM by Zip.
