Dear all,
I am using Slic3r on the command line to slice some meshes to svg format for something other than 3D printing. Since slic3r is designed to produce slices for a printer, it is changing the coordinate system by automatically centering the structure on a build plate. I would like the slices to keep the same coordinate system as the mesh. For example, if I build a structure so that the mesh is centered on the origin, I would like the slices to be appropriated arranged around the origin as well.
I have tried passing the flag --dont-arrange at the command line, but this does not seem to have any effect at all on the results.
Is there a way that I can simply turn this recentering feature off? Otherwise, would anyone be willing to share a different solution with me?
Thanks very much!
