PWM frequency of fan only about 4Hz August 24, 2012 02:48PM |
Re: PWM frequency of fan only about 4Hz August 24, 2012 06:20PM |
if(pwm_count==0) { #if EXT0_HEATER_PIN>-1 if((pwm_pos_set[0] = pwm_pos[0])>0) WRITE(EXT0_HEATER_PIN,1); #endif #if defined(EXT1_HEATER_PIN) && EXT1_HEATER_PIN>-1 if((pwm_pos_set[1] = pwm_pos[1])>0) WRITE(EXT1_HEATER_PIN,1); #endif #if defined(EXT2_HEATER_PIN) && EXT2_HEATER_PIN>-1 if((pwm_pos_set[2] = pwm_pos[2])>0) WRITE(EXT2_HEATER_PIN,1); #endif #if FAN_PIN>-1 if((pwm_pos_set[3] = pwm_pos[3])>0) WRITE(FAN_PIN,1); #endif } #if EXT0_HEATER_PIN>-1 if(pwm_pos_set[0] == pwm_count) WRITE(EXT0_HEATER_PIN,0); #endif #if defined(EXT1_HEATER_PIN) && EXT1_HEATER_PIN>-1 if(pwm_pos_set[1] == pwm_count) WRITE(EXT1_HEATER_PIN,0); #endif #if defined(EXT2_HEATER_PIN) && EXT2_HEATER_PIN>-1 if(pwm_pos_set[2] == pwm_count) WRITE(EXT2_HEATER_PIN,0); #endif #if FAN_PIN>-1 if(pwm_pos_set[3] == pwm_count) WRITE(FAN_PIN,0); #endif
Re: PWM frequency of fan only about 4Hz August 24, 2012 06:47PM |
Re: PWM frequency of fan only about 4Hz August 25, 2012 02:50AM |
Re: PWM frequency of fan only about 4Hz January 12, 2014 05:06AM |
Re: PWM frequency of fan only about 4Hz January 12, 2014 05:18AM |
Re: PWM frequency of fan only about 4Hz January 12, 2014 12:51PM |
Re: PWM frequency of fan only about 4Hz January 12, 2014 12:57PM |
