Trying out repetier, trying to get the firmware loaded right. I have Mendel Prusa, running on RAMPS 1.4 on an arduino Mega 2560. Went through the configuration.H file, reset everything that looked appropriate. I can connect, heat up the extruder, manually extrude, manually move X,Y and Z,. I have mechanical endstops, which worked fine when I was running pronterface under sprinter. I tell it to go home, the axis move in the right directions but the endstop switches for x and y don't stop the movement. The z endstop works fine
I set up endstops like this
//#define ENDSTOP_PULLUP_X_MIN true
//#define ENDSTOP_PULLUP_Y_MIN true
//#define ENDSTOP_PULLUP_Z_MIN true
//#define ENDSTOP_PULLUP_X_MAX true
//#define ENDSTOP_PULLUP_Y_MAX true
//#define ENDSTOP_PULLUP_Z_MAX true
//set to true to invert the logic of the endstops
#define ENDSTOP_X_MIN_INVERTING false
#define ENDSTOP_Y_MIN_INVERTING false
#define ENDSTOP_Z_MIN_INVERTING false
#define ENDSTOP_X_MAX_INVERTING false
#define ENDSTOP_Y_MAX_INVERTING false
#define ENDSTOP_Z_MAX_INVERTING false
//If your axes are only moving in one direction, make sure the endstops are connected properly.
//If your axes move in one direction ONLY when the endstops are triggered, set ENDSTOPS_INVERTING to true here
//// ADVANCED SETTINGS - to tweak parameters
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z true
#define DISABLE_E false
// Inverting axis direction
#define INVERT_X_DIR false
#define INVERT_Y_DIR true
#define INVERT_Z_DIR false
//// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
My original sprinter setup was like this
Any hints, please?
