Repetier-Host-Mac_0_40 crash in G-Code Editor
October 01, 2012 07:08PM
Hello,
first of all, thank you for your great software! Unfortunately, i had several crashes in the G-Code Editor. The attached files contains
one of the crash reports.
Regards,
Temporalis
open | download - Repetier Crash.txt (48.3 KB)
Re: Repetier-Host-Mac_0_40 crash in G-Code Editor
October 02, 2012 12:23PM
The output shows nothing special. Code area seems to belong to OpenGL stuff.
Are you testing with large objects? In that case it could be a memory issue. You could monitor memory usage to check that.
Did you do anything special like switching visible layer when the crash occured?
October 05, 2012 04:56PM
Hallo.
: Are you testing with large objects?
Not really... [www.thingiverse.com]. I was editing the Start, Kill and Pause scripts. The crash occurred trying to exit
the Editor. The MacPro has 4GB RAM. I'am still trying to reproduce the crashes, after initially it came very often :-(
BTW... why is there no "Continue" Script (run after Pause?)
Regards,
Temporalis
October 05, 2012 06:08PM
"Trying to exit" means you wanted to switch the tab?
No "Continue" script, because I don't think one is needed. The host remembers the state when pause started and sets the printer back into the inital state when pause started. The only reason for a pause script itself is to move the extruder away from the object in a fashion you prefer.
October 06, 2012 06:39PM
> tab?
Yes!
Hmmm... sorry, to read that. I would need a continue script,
because i drive back the filament and turn off the temperature of the
extruder while in pause mode. To turn the temperature on and reset
the filament position, it would be nice to have a continue script.
Regards,
Temporalis
October 13, 2012 12:48PM
I continue to have crashes in the G-Code Editor. There is no way, this has to do with the other modules as it crashed
while deleting characters or moviing the cursor in the Start Code Editor.
There was plenty of free Memory available as shown by "Memory Scope".
Perhaps it has something to do with the "Help" Display beneath the edit window, because its contents are
constantly updated while editing.
Regards
open | download - Repetier GEditor Crash.txt (48.3 KB)
open | download - G-Code Editor Crash 2.txt (46.5 KB)
October 14, 2012 03:50AM
My guess is, that there is a timing problem when starting the update process, but I'm not sure. The log gives no method names for the host. Could you test with this version: [dl.dropbox.com]
It's the same host only compiled with debug information, so I can narrow the code causing the crash. Thanks.
October 14, 2012 11:39AM
Hi.
I tried the debug version and was not able the crash the editor... i will continue to use
this one ;-)
Just to make sure, i started the non debug version again and crashed it in under 20 seconds.
Could therefor also be a problem of unintended writing on the stack.
Regards
January 20, 2013 07:48AM
Hi, im reviving this thread to tell that im having the same crash with the mac version (0.51)
