Hi Flyer!
I think the changed COM Port numbering has nothing to do with Repetier Host.
I assume you're using an usb-ttl converter to connect to your GEN7?
By connecting one of those to an usb port the driver creates a "virtual com port" for you. Don't ask me in detail how windows handles the numbering of it's com ports but the numbers might change (f.ex. if you connect it to another usb port , or the port is allready in use ...)
As far is I can see you've also missunderstood the "COM Port Option" in Arduino IDE. The option tells the arduino ide on which com port your USB-TTL Converter is "connected" respectivley which one to use to upload the firmware. It has nothing todo with which COM Port your Converter shows up in Repetier Host or windows.
You can easily change the naming of the virtual com port through your windows "hardware manager" (see screenshots)
I'm quite sure the changed COM Port is not related to your problems
