RepetierHost v0.82b using skeinforge produces a window with the error message
"could not find the generated G-code file".
This is due to the skeinforge setting "Export, File Extension" being set to add "gcode".
This is like the third time I fell for this setting after installing RepetierHost as I think that the output gcode file should have the ".gcode" extension to help me find the right files later. But if the extension is added in skeinforge, it can't find it automatically to load it after slicing.
Maybe we coud add it as an option in RepetierHost?
But for someone getting this message, check this setting as well as the directory RepetierHost is looking in that it is the same as the skeinforge output directory. Either one being mis-set will cause this error.
