"could not find the generated G-code file"
Posted by rrr7
January 09, 2013 09:31PM
RepetierHost v0.82b using skeinforge produces a window with the error message
"could not find the generated G-code file".
This is due to the skeinforge setting "Export, File Extension" being set to add "gcode".
This is like the third time I fell for this setting after installing RepetierHost as I think that the output gcode file should have the ".gcode" extension to help me find the right files later. But if the extension is added in skeinforge, it can't find it automatically to load it after slicing.
Maybe we coud add it as an option in RepetierHost?
But for someone getting this message, check this setting as well as the directory RepetierHost is looking in that it is the same as the skeinforge output directory. Either one being mis-set will cause this error.
Re: "could not find the generated G-code file"
January 11, 2013 11:35PM
Try disabling Comb in SF. I get this with some models if I have Comb turned on, which I do most of the time.
