I have a few issues with my set up I hope someone can shed some light on.
My printers zero coords are X Right, Y Front, Z Down. My settings in printer shape however have the "origin dot" in the 3d view in the front left of the screen causing the whole thing to mirror funny,.. My settings are: Home X: min, Home Y: max, Home Z: Min, X min: 0, X max: 165, Bed Left: 0, Y min: 0, Y max: 200, Bef Front: 0.
In order to move the origin dot to the back left I need make Bed Left: -200 and then all the gcode is off because when I drop an SLT it has a negative in the translation coords...
My second problem is when I center the part and do a dry run everything goes well and it prints in the middle but outside of a dry run the part starts to print with its corner in (0,0). Its as if it skips the first G1 that moved to the offset print coords.
Any ideas??
