OPS doesnt work?
Posted by nikbjo
OPS doesnt work?
February 05, 2013 01:54PM
I have trouble getting OPS to work
I have compiled firmware with #define USE_OPS 1
and has eeprom settings as:
OPS operation mode: 2
OPS move after x% retract [%]: 0
OPS min. distance for fil. retraction [mm]: 0.80
OPS retraction length [mm]: 5.00
OPS retraction backlash [mm]: 0.00
But it does never retract anything during moves. Any suggestions?
Re: OPS doesnt work?
February 06, 2013 10:23AM
never tested this with 0. You always need some retraction to start or the filament will start stringing. So perhaps 20% or so. Maybe that is the reason. Also 5mm retraction is very much. Good hotends need only 1mm and 2-3 should nearly always suffice.
One other point with ops is that the extruder starts with the set max speed - no acceleration. If you hear the extruder loosing steps during retraction lower max speed until you don't hear this any more.
February 08, 2013 02:01PM
it worked when changing move after x% retraction > 0.
February 08, 2013 02:10PM
Good to know. I will look what is the reason and see if i can make it run with 0 or add a condition to prevent this problem.
