Z speed issue after updating Host to version 84 February 25, 2013 11:10AM |
Re: Z speed issue after updating Host to version 84 March 01, 2013 07:40PM |
Re: Z speed issue after updating Host to version 84 March 03, 2013 03:00AM |
// For higher precision you can reduce the speed for the second test on the endstop // during homing operation. The homing speed is divided by the value. 1 = same speed, 2 = half speed #define ENDSTOP_X_RETEST_REDUCTION_FACTOR 2 #define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 2 #define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 2
Re: Z speed issue after updating Host to version 84 March 07, 2013 04:31PM |
Re: Z speed issue after updating Host to version 84 March 12, 2013 08:46PM |
Re: Z speed issue after updating Host to version 84 March 13, 2013 04:38AM |
if(zaxis) { if ((MIN_HARDWARE_ENDSTOP_Z && Z_MIN_PIN > -1 && Z_HOME_DIR==-1) || (MAX_HARDWARE_ENDSTOP_Z && Z_MAX_PIN > -1 && Z_HOME_DIR==1)){ UI_STATUS_UPD(UI_TEXT_HOME_Z); steps = (printer_state.zMaxSteps-printer_state.zMinSteps) * Z_HOME_DIR; printer_state.currentPositionSteps[2] = -steps; move_steps(0,0,2*steps,0,homing_feedrate[2],true,true); printer_state.currentPositionSteps[2] = 0; move_steps(0,0,axis_steps_per_unit[2]*-ENDSTOP_Z_BACK_MOVE * Z_HOME_DIR,0,homing_feedrate[2]/ENDSTOP_Z_RETEST_REDUCTION_FACTOR,true,false); move_steps(0,0,axis_steps_per_unit[2]*2*ENDSTOP_Z_BACK_MOVE * Z_HOME_DIR,0,homing_feedrate[2]/ENDSTOP_Z_RETEST_REDUCTION_FACTOR,true,true); #if defined(ENDSTOP_Z_BACK_ON_HOME) if(ENDSTOP_Z_BACK_ON_HOME > 0) move_steps(0,0,axis_steps_per_unit[2]*-ENDSTOP_Z_BACK_ON_HOME * Z_HOME_DIR,0,homing_feedrate[2],true,false); #endif printer_state.currentPositionSteps[2] = (Z_HOME_DIR == -1) ? printer_state.zMinSteps : printer_state.zMaxSteps; } }
OUT_P_F_LN("Z homing speed:",homing_feedrate[2]);
void move_steps(long x,long y,long z,long e,float feedrate,bool waitEnd,bool check_endstop) {
void move_steps(long x,long y,long z,long e,float feedrate,bool waitEnd,bool check_endstop) { if(z) { OUT_P_L("Z-Steps:",z); OUT_P_F_LN(" Feedrate:",feedrate); }
Re: Z speed issue after updating to Host version .84, firmware .81 March 25, 2013 05:39PM |
Re: Z speed issue after updating to Host version .84, firmware .81 March 25, 2013 06:55PM |
Re: Z speed issue after updating to Host version .84, firmware .81 March 25, 2013 08:23PM |
Re: Z speed issue after updating to Host version .84, firmware .81 March 26, 2013 03:39AM |
Re: Z speed issue after updating Host to version 84 March 26, 2013 08:20PM |
Re: Z speed issue after updating Host to version 84 March 27, 2013 03:26AM |
