I'm having problems getting OPS to work.
I'm using the latest firmware compiled from github on a sanguinololu 1.3 board with a 1284p.
I have OPS enabled in the firmware but set to disabled in eeprom.
When its set as above, I can print fine.
As soon as I change the setting in eeprom to classic or fast mode, the extruder stops working, i.e. no filament is being pushed through into the hot end.
If I start with the mode set to 1 or 2 (and not 0) the extruder does not work.
If I switch back to mode 0 using the eeprom, the extruder will start working again.
The only settings I have changed in the firmware are the steps per mm, bed size, end stop settings and a few pins for an LCD screen.
Any ideas?
Based in Darlington, North East
