X/Y/E Motors Do Not Turn. Help? July 09, 2013 11:25PM |
Re: X/Y/E Motors Do Not Turn. Help? July 10, 2013 03:18AM |
Re: X/Y/E Motors Do Not Turn. Help? July 11, 2013 03:29PM |
Re: X/Y/E Motors Do Not Turn. Help? July 11, 2013 04:26PM |
Re: X/Y/E Motors Do Not Turn. Help? July 11, 2013 08:58PM |
Re: X/Y/E Motors Do Not Turn. Help? July 12, 2013 05:58AM |
Re: X/Y/E Motors Do Not Turn. Help? July 12, 2013 06:17AM |
Re: X/Y/E Motors Do Not Turn. Help? July 14, 2013 03:12PM |
Re: X/Y/E Motors Do Not Turn. Help? July 15, 2013 05:57AM |
Overridden if EEPROM activated. */ #define XAXIS_STEPS_PER_MM 3200 /** \brief Number of steps for a 1mm move in y direction. For xy gantry use 2*belt moved! Overridden if EEPROM activated.*/ #define YAXIS_STEPS_PER_MM 3200 /** \brief Number of steps for a 1mm move in z direction Overridden if EEPROM activated.*/ #define ZAXIS_STEPS_PER_MM 3200
Re: X/Y/E Motors Do Not Turn. Help? July 16, 2013 06:32PM |
Re: X/Y/E Motors Do Not Turn. Help? July 17, 2013 03:08AM |
Re: X/Y/E Motors Do Not Turn. Help? July 17, 2013 05:16AM |
Re: X/Y/E Motors Do Not Turn. Help? July 17, 2013 09:11AM |
Re: X/Y/E Motors Do Not Turn. Help? July 17, 2013 09:23AM |
Re: X/Y/E Motors Do Not Turn. Help? July 17, 2013 09:37AM |
Re: X/Y/E Motors Do Not Turn. Help? July 17, 2013 09:56AM |
Re: X/Y/E Motors Do Not Turn. Help? July 17, 2013 10:06AM |
Re: X/Y/E Motors Do Not Turn. Help? July 17, 2013 10:31AM |
Re: X/Y/E Motors Do Not Turn. Help? July 17, 2013 11:17AM |
Re: X/Y/E Motors Do Not Turn. Help? July 18, 2013 12:22AM |
Re: X/Y/E Motors Do Not Turn. Help? July 18, 2013 05:07AM |
/** Drive settings for printers with cartesian drive systems */ /** \brief Number of steps for a 1mm move in x direction. For xy gantry use 2*belt moved! Overridden if EEPROM activated. */ #define XAXIS_STEPS_PER_MM 3200 /** \brief Number of steps for a 1mm move in y direction. For xy gantry use 2*belt moved! Overridden if EEPROM activated.*/ #define YAXIS_STEPS_PER_MM 3200 /** \brief Number of steps for a 1mm move in z direction Overridden if EEPROM activated.*/ #define ZAXIS_STEPS_PER_MM 3200 ... // ########################################################################################## // ## Movement settings ## // ########################################################################################## ... /** Maximum feedrate, the system allows. Higher feedrates are reduced to these values. The axis order in all axis related arrays is X, Y, Z Overridden if EEPROM activated. */ #define MAX_FEEDRATE_X 200 // ? see Repetier comment: 40000 / 3200 = 12.5 #define MAX_FEEDRATE_Y 200 // ? dito #define MAX_FEEDRATE_Z 5 /** Speed in mm/min for finding the home position. Overridden if EEPROM activated. */ #define HOMING_FEEDRATE_X 80 // ? dito #define HOMING_FEEDRATE_Y 80 // ? dito #define HOMING_FEEDRATE_Z 3 ... //// Acceleration settings /** \brief X, Y, Z max acceleration in mm/s^2 for printing moves or retracts. Make sure your printer can go that high! Overridden if EEPROM activated. */ #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1500 //? #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1500 //? #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100 /** \brief X, Y, Z max acceleration in mm/s^2 for travel moves. Overridden if EEPROM activated.*/ #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000 //? #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000 //? #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 100
Re: X/Y/E Motors Do Not Turn. Help? July 18, 2013 05:40AM |
Re: X/Y/E Motors Do Not Turn. Help? July 18, 2013 05:50AM |
Re: X/Y/E Motors Do Not Turn. Help? July 18, 2013 05:54AM |
Re: X/Y/E Motors Do Not Turn. Help? July 18, 2013 06:50AM |
Re: X/Y/E Motors Do Not Turn. Help? July 18, 2013 08:52AM |
Re: X/Y/E Motors Do Not Turn. Help? July 18, 2013 10:33AM |
Re: X/Y/E Motors Do Not Turn. Help? July 19, 2013 12:33PM |
Re: X/Y/E Motors Do Not Turn. Help? July 19, 2013 02:48PM |
