sd card automation
Posted by myk68
sd card automation
August 24, 2013 09:37AM
Hi all
anyone know where i can look to find out how i use the sd card reader on the megatronics v2.0 to automate a print. I placed a file on the card and started the job but disconnecting the usb then stops the print.??
I have to missing something.
Cheers for any help
Mike
Re: sd card automation
August 24, 2013 09:44AM
Did you start the job from the main toolbar or within the sd card windows? If you start it from the sd manager windows it should continue running even when there is no connection.
August 24, 2013 01:14PM
ah. good question, i'll let you know. currently having issues printing the perimeter test.
mike
August 26, 2013 01:40PM
Hi
right got things working again. back to the automation problem
I have added a gcode file to the memory card thru the sd reader on the pc as it never shows when i save it thru the sd card manager. file saved as thinwall.gcode
on the sd card manager this shows as thinwa~.gco??
I have run this and once the temp starts to rise I have pulled the usb lead and all lights go out and nothing else happens, this is the heater light as well so it all cools down again.
I have waited for it to start printing and then pulled the lead and still the same. I then tried the same with starting the print then disconnecting then pulling the usb lead and the same thing happens.
whenever I unplug the usb so i can take the pc away it all stops.
What am I missing??
Mike
August 26, 2013 01:58PM
myk68 Wrote:
> Hi
> automation problem
> thinwall.gcode
> thinwa~.gco??
Only dos notation with 8.3 chars for a filename are supported. Longer names get changed as you see.
> same thing happens.
> away it all stops.
Looks like disconnecting causes a reset on your board.
Do you have a lcd display? Then you would see the restart.
You could try different reset on connect methods in printer settings and see if that changes the reset behaviour on disconnect.
BTW: What board are you using? I'm quite sure this does not happen with my ramps board.
August 26, 2013 02:36PM
> board.
> restart.
I havent got an LCD yet thats for later :-)
I am using the Megatronics v2.0
what have you got your settings on. mine are -
baud rate 250000
transfer protocol autodetect
reset on connect DTR toggle, also tried DTR low>high>low
reset on emergency send emergency command and reconnect
recieve cache 127
Ping pong ive tried on and off
August 26, 2013 02:59PM
this may be a daft question but when i pull the usb it has nothing powering it, as this comes from the usb
should i have another power supply going in other than the 12v for the motors??
Mike
August 26, 2013 03:37PM
Good point. I do not know how Megatronics works. For ramps you need a special diode to allow powering over 12v. So if you have something similar you unpower the elevtronics with unplugging, which of course would stop the print. Check the documentation and see if you can measure 5v on some pins that should have 5v like the lcd connector.
August 28, 2013 04:46PM
thats got it thank you for the help
mike
