Full Graphic Smart LCD Controller August 28, 2013 08:34PM |
Re: Full Graphic Smart LCD Controller August 29, 2013 08:58AM |
Re: Full Graphic Smart LCD Controller October 16, 2013 04:20PM |
Re: Full Graphic Smart LCD Controller October 25, 2013 07:42PM |
Re: Full Graphic Smart LCD Controller October 26, 2013 02:36AM |
Re: Full Graphic Smart LCD Controller October 26, 2013 02:35PM |
Re: Full Graphic Smart LCD Controller October 26, 2013 03:13PM |
Re: Full Graphic Smart LCD Controller October 26, 2013 04:12PM |
25c25 < #define REPETIER_VERSION "0.90alpha" --- > #define REPETIER_VERSION "0.90" 38c38 < //#define INCLUDE_DEBUG_NO_MOVE --- > #define INCLUDE_DEBUG_NO_MOVE 103a104,109 > #if DRIVE_SYSTEM==3 || DRIVE_SYSTEM==4 > #define NONLINEAR_SYSTEM true > #else > #define NONLINEAR_SYSTEM false > #endif > 312c318 < #if DRIVE_SYSTEM==3 --- > #if NONLINEAR_SYSTEM 314,316d319 < extern void set_delta_position(long xaxis, long yaxis, long zaxis); < extern float rodMaxLength; < extern void split_delta_move(uint8_t check_endstops,uint8_t pathOptimize, uint8_t softEndstop); 322a326,331 > #ifndef FEATURE_DITTO_PRINTING > #define FEATURE_DITTO_PRINTING false > #endif > #if FEATURE_DITTO_PRINTING && NUM_EXTRUDER!=2 > #error Ditto printin requires exactly 2 extruder. > #endif 325,328c334,336 < < extern unsigned long previousMillisCmd; < extern unsigned long maxInactiveTime; < extern unsigned long stepperInactiveTime; --- > extern millis_t previousMillisCmd; > extern millis_t maxInactiveTime; > extern millis_t stepperInactiveTime; 378,379c386,387 < void write_command(GCode *code); < void selectFile(char *filename); --- > void writeCommand(GCode *code); > bool selectFile(char *filename,bool silent=false); 416,420c424 < #if DRIVE_SYSTEM==3 < #define SIN_60 0.8660254037844386 < #define COS_60 0.5 < < --- > #if NONLINEAR_SYSTEM
Re: Full Graphic Smart LCD Controller October 27, 2013 03:12AM |
Re: Full Graphic Smart LCD Controller November 06, 2013 03:22AM |
Re: Full Graphic Smart LCD Controller November 07, 2013 06:04PM |
Re: Full Graphic Smart LCD Controller November 29, 2013 04:12AM |
Re: Full Graphic Smart LCD Controller November 30, 2013 05:04AM |
Re: Full Graphic Smart LCD Controller November 30, 2013 05:41AM |
Re: Full Graphic Smart LCD Controller November 30, 2013 05:56AM |
// printer ready - code 7 // *...* 17 // .*.*. 10 // ..*.. 4 // *...* 17 // ..*.. 4 // .*.*. 10 // *...* 17 // *...* 17
Re: Full Graphic Smart LCD Controller November 30, 2013 06:34AM |
Re: Full Graphic Smart LCD Controller December 08, 2013 08:37AM |
Re: Full Graphic Smart LCD Controller December 08, 2013 11:24AM |
Re: Full Graphic Smart LCD Controller December 08, 2013 07:06PM |
Re: Full Graphic Smart LCD Controller December 14, 2013 12:30PM |
Re: Full Graphic Smart LCD Controller December 15, 2013 02:32AM |
Re: Full Graphic Smart LCD Controller December 15, 2013 02:54AM |
Re: Full Graphic Smart LCD Controller December 15, 2013 03:17AM |
Re: Full Graphic Smart LCD Controller December 15, 2013 03:31AM |
Re: Full Graphic Smart LCD Controller December 15, 2013 05:04AM |
Re: Full Graphic Smart LCD Controller December 15, 2013 05:08AM |
Re: Full Graphic Smart LCD Controller December 15, 2013 05:49AM |
Re: Full Graphic Smart LCD Controller December 21, 2013 02:35AM |
Re: Full Graphic Smart LCD Controller December 21, 2013 03:37AM |
Re: Full Graphic Smart LCD Controller January 10, 2014 02:29PM |
peter6960
Thanks... Ordered some ST7920 right away on ebay, now that my favourite firmware supports it (:
Peter
