Repetier Firmware: Dual Y Steppers December 11, 2013 03:49AM |
Re: Repetier Firmware: Dual Y Steppers December 11, 2013 06:24AM |
/**************** duplicate motor driver *************** If you have an unused extruder stepper free, you could use it to drive the second z motor instead of driving both with a single stepper. The same works for the other axis if needed. */ #define FEATURE_TWO_XSTEPPER false #define X2_STEP_PIN E1_STEP_PIN #define X2_DIR_PIN E1_DIR_PIN #define X2_ENABLE_PIN E1_ENABLE_PIN #define FEATURE_TWO_YSTEPPER false #define Y2_STEP_PIN E1_STEP_PIN #define Y2_DIR_PIN E1_DIR_PIN #define Y2_ENABLE_PIN E1_ENABLE_PIN #define FEATURE_TWO_ZSTEPPER false #define Z2_STEP_PIN E1_STEP_PIN #define Z2_DIR_PIN E1_DIR_PIN #define Z2_ENABLE_PIN E1_ENABLE_PIN
Re: Repetier Firmware: Dual Y Steppers December 11, 2013 06:30AM |
Re: Repetier Firmware: Dual Y Steppers December 12, 2013 10:28AM |
