The testgenerator is only disabled. Do into Host install directore then into data and open custom.ini and search for
; Don't include testgenerator
removeTestgenerator=1
replace that with 0 and you get the generator back.
Graphic LCDs are very resource hungry. Especially computation time as the avr has to compute the characters etc. and sends them per software SPI to the display plus it needs some extra ram to store computed characters (around 200 byte extra). This takes around 0.1 seconds per refresh. When using the menu update frequency increases making stops more likely. Normally incresing buffers and delta segments per line would help, but with the GLCD connected you even had to decrese delta segments per line to work stable, so that is no option on a AVR except if it is a 1286 with 16KB ram. So that is the price for the nice display.
Visit us on
Facebook and
Twitter!
