Is it posible to compile repetier firmware for a Atmega328P.
I only need xyz motion, arc support and pwm fan (for laser ttl) control.
Could be nice with sdcard support, but not high priority.
Is for my laser engraver project.
I doubt it would fit. It's already close for 64kb which are only possible if you disable sd and lcd. But you can try to compile it and see how long it is. The Arduino IDE shows size after compilation. With all features we come near 128kB, so you need to disable really a lot.
Repetier-Software - the home of Repetier-Host (Windows, Linux and Mac OS X) and Repetier-Firmware. Repetier-Server - the solution to control your printer from everywhere.
I installed GRBL 0.9 dev as is has got PWM spindle control. 0.8 don't have pwm, that's why i looked at repetier. But think I will stick with GRBL for my laser as it's works. :-)
But maybe I will try repetier on my old sanguinololu to control the laser with 4 axis later.
Edited 1 time(s). Last edit at 03/21/2014 03:48AM by Kenzu.
