Hello,
Was reluctant to upgrade to .95 after my first attempt were not so successful with slicing. Another thread here helped me with the sli3r directory settings. I have another issue that I did not have with .90 which also deals with sli3r, but not sure how to fix it.
The gcode generated is not in the position I want it. I have a piece at 0,0 which is the bottom left corner of my machine. When I run sli3r from Repetier, I see this in the promt in Repetier:
12:02:32.760 : Slic3r command:C:\Program Files\Repetier-Host\Slic3r\slic3r.exe --load "C:\Users\wiso\AppData\Local\RepetierHost\slic3r.ini" --print-center 180,50 -o "C:\Users\wiso\AppData\Local\RepetierHost\composition.gcode" "C:\Users\wiso\AppData\Local\RepetierHost\composition.obj"
Where is this --print-center 180,50 coming from!? I never set anything besides that I want the prints to center around 0,0. In .90 I never had this issue, and I am not sure where Repetier is getting these paramters. Any ideas?
