Hi Repetier,
Thanks for the information. I checked and the log file was not activated so I activated it. Below are the results. Hopefully this helps. The protocol was set to Auto detect so I switched that to ASCII but still have the same issue.
< 07:52:51.890 : OpenGL version:3.3.0 - Build 8.15.10.2626
< 07:52:51.890 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_EXT_texture_snorm GL_ARB_blend_func_extended GL_INTEL_performance_queries GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_geometry_shader4 GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_texture_multisample GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_ARB_vertex_array_object GL_ARB_provoking_vertex
< 07:52:51.890 : OpenGL renderer:Intel(R) HD Graphics 4000
< 07:52:51.891 : Using fast VBOs for rendering is possible
> 07:52:59.603 : start
> 07:52:59.610 : echo: External Reset
> 07:52:59.610 : Marlin 1.0.0
> 07:52:59.610 : echo: Last Updated: Mar 20 2014 21:51:59 | Author: (SGraber, Cerberus Pup 170)
> 07:52:59.610 : Compiled: Mar 20 2014
> 07:52:59.610 : echo: Free Memory: 11512 PlannerBufferBytes: 1232
> 07:52:59.610 : echo
tored settings retrieved
> 07:52:59.610 : echo
teps per unit:
> 07:52:59.610 : echo: M92 X160.00 Y160.00 Z160.00 E191.50
> 07:52:59.610 : echo:Maximum feedrates (mm/s):
> 07:52:59.610 : echo: M203 X150.00 Y150.00 Z150.00 E200.00
> 07:52:59.610 : echo:Maximum Acceleration (mm/s2):
> 07:52:59.610 : echo: M201 X9000 Y9000 Z9000 E9000
> 07:52:59.610 : echo:Acceleration: S=acceleration, T=retract acceleration
> 07:52:59.610 : echo: M204 S3000.00 T3000.00
> 07:52:59.610 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
> 07:52:59.610 : echo: M205 S0.00 T0.00 B20000 X20.00 Z20.00 E20.00
> 07:52:59.610 : echo:Home offset (mm):
> 07:52:59.610 : echo: M206 X0.00 Y0.00 Z0.00
> 07:52:59.610 : echo:Endstop adjustment (mm):
> 07:52:59.610 : echo: M666 X-1.24 Y-1.54 Z-1.97
> 07:52:59.610 : echo
elta Geometry adjustment:
> 07:52:59.610 : echo: M666 A(xa)0.00 B(ya)-0.36 C(xc)1.35 R81.50 D215.43 H130.20 P0.00
> 07:52:59.610 : echo
ID settings:
> 07:52:59.610 : echo: M301 P41.80 I3.75 D112.39
< 07:53:00.165 : N1 M110 *2
< 07:53:00.165 : N2 M115 *4
< 07:53:00.165 : N3 M111 S6 *68
> 07:53:02.465 : echo
D init fail
> 07:53:02.476 : ok
> 07:53:02.476 : ok
> 07:53:02.476 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[
www.mendel-parts.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Cerberus 170 EXTRUDER_COUNT:1
< 07:53:02.476 : N4 M111 S6 *67
< 07:53:02.476 : N5 M105 *2
> 07:53:02.492 : ok
> 07:53:02.492 : ok
> 07:53:02.492 : ok
> 07:53:02.492 : ok T:25.1 /0.0 B:19.9 /0.0 T0:25.1 /0.0 @:0 B@:0
< 07:53:02.493 : N6 M80 *61
< 07:53:02.493 : N7 M80 *60
< 07:53:02.493 : N8 M220 S100 *73
< 07:53:02.509 : N9 M221 S100 *73
> 07:53:02.509 : ok
> 07:53:02.509 : ok
> 07:53:02.509 : ok
< 07:53:02.509 : N10 M111 S6 *118
> 07:53:02.513 : ok
> 07:53:02.513 : ok
< 07:53:02.981 : N11 G28 *3
< 07:53:03.273 : N12 M105 *52
> 07:53:04.466 : ok
> 07:53:04.466 : ok T:19.8 /0.0 B:20.2 /0.0 T0:19.8 /0.0 @:0 B@:0
< 07:53:05.258 : N13 M140 S90 *78
> 07:53:05.266 : ok
< 07:53:06.327 : N14 M105 *50
> 07:53:06.339 : ok T:20.4 /0.0 B:21.1 /90.0 T0:20.4 /0.0 @:0 B@:0
< 07:53:09.387 : N15 M105 *51
> 07:53:10.800 : start
> 07:53:10.800 : echo: Brown out Reset
> 07:53:10.800 : Marlin 1.0.0
> 07:53:10.800 : echo: Last Updated: Mar 20 2014 21:51:59 | Author: (SGraber, Cerberus Pup 170)
> 07:53:10.800 : Compiled: Mar 20 2014
> 07:53:10.800 : echo: Free Memory: 11512 PlannerBufferBytes: 1232
> 07:53:10.800 : echo
> 07:53:10.800 : echo
teps per unit:
> 07:53:10.800 : echo: M92 X160.00 Y160.00 Z160.00 E191.50
> 07:53:10.809 : echo:Maximum feedrates (mm/s):
> 07:53:10.809 : echo: M203 X150.00 Y150.00 Z150.00 E200.00
> 07:53:10.809 : echo:Maximum Acceleration (mm/s2):
> 07:53:10.809 : echo: M201 X9000 Y9000 Z9000 E9000
> 07:53:10.809 : echo:Acceleration: S=acceleration, T=retract acceleration
> 07:53:10.809 : echo: M204 S3000.00 T3000.00
> 07:53:10.809 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
> 07:53:10.809 : echo: M205 S0.00 T0.00 B20000 X20.00 Z20.00 E20.00
> 07:53:10.809 : echo:Home offset (mm):
> 07:53:10.809 : echo: M206 X0.00 Y0.00 Z0.00
> 07:53:10.809 : echo:Endstop adjustment (mm):
> 07:53:10.809 : echo: M666 X-1.24 Y-1.54 Z-1.97
> 07:53:10.809 : echo
> 07:53:10.809 : echo: M666 A(xa)0.00 B(ya)-0.36 C(xc)1.35 R81.50 D215.43 H130.20 P0.00
> 07:53:10.809 : echo
ID settings:
> 07:53:10.810 : echo: M301 P41.80 I3.75 D112.39
< 07:53:11.240 : N1 M110 *2
< 07:53:11.240 : N2 M115 *4
< 07:53:11.240 : N3 M111 S6 *68
> 07:53:14.206 : echo
D init fail
> 07:53:14.218 : ok
> 07:53:14.218 : ok
> 07:53:14.218 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[
< 07:53:14.218 : N4 M111 S6 *67
< 07:53:14.224 : N5 M80 *62
> 07:53:14.224 : ok
> 07:53:14.224 : ok
< 07:53:14.227 : N6 M104 S200 *65
< 07:53:14.227 : N7 M105 *0
> 07:53:14.247 : ok
> 07:53:14.248 : ok
> 07:53:14.248 : ok
> 07:53:14.248 : ok T:26.4 /200.0 B:21.8 /0.0 T0:26.4 /200.0 @:0 B@:0
< 07:53:14.248 : N8 M220 S100 *73
< 07:53:14.248 : N9 M221 S100 *73
< 07:53:14.249 : N10 M111 S6 *118
> 07:53:14.263 : ok
> 07:53:14.263 : ok
> 07:53:14.263 : ok
< 07:53:15.503 : N11 M105 *55
> 07:53:15.512 : ok T:18.0 /200.0 B:19.8 /0.0 T0:18.0 /200.0 @:127 B@:0
< 07:53:18.559 : N12 M105 *52
> 07:53:18.570 : ok T:22.3 /200.0 B:20.4 /0.0 T0:22.3 /200.0 @:127 B@:0
< 07:53:20.789 : N13 M140 S90 *78
> 07:53:20.795 : ok
< 07:53:21.618 : N14 M105 *50
> 07:53:22.824 : start
> 07:53:22.824 : echo: Brown out Reset
> 07:53:22.824 : Marlin 1.0.0
> 07:53:22.872 : echo: Last Updated: Mar 20 2014 21:51:59 | Author: (SGraber, Cerberus Pup 170)
> 07:53:22.872 : Compiled: Mar 20 2014
> 07:53:22.872 : echo: Free Memory: 11512 PlannerBufferBytes: 1232
> 07:53:22.872 : echo
> 07:53:22.873 : echo
teps per unit:
> 07:53:22.873 : echo: M92 X160.00 Y160.00 Z160.00 E191.50
> 07:53:22.873 : echo:Maximum feedrates (mm/s):
> 07:53:22.873 : echo: M203 X150.00 Y150.00 Z150.00 E200.00
> 07:53:22.873 : echo:Maximum Acceleration (mm/s2):
> 07:53:22.873 : echo: M201 X9000 Y9000 Z9000 E9000
> 07:53:22.873 : echo:Acceleration: S=acceleration, T=retract acceleration
> 07:53:22.873 : echo: M204 S3000.00 T3000.00
> 07:53:22.873 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
> 07:53:22.873 : echo: M205 S0.00 T0.00 B20000 X20.00 Z20.00 E20.00
> 07:53:22.873 : echo:Home offset (mm):
> 07:53:22.873 : echo: M206 X0.00 Y0.00 Z0.00
> 07:53:22.873 : echo:Endstop adjustment (mm):
> 07:53:22.873 : echo: M666 X-1.24 Y-1.54 Z-1.97
> 07:53:22.873 : echo
> 07:53:22.873 : echo: M666 A(xa)0.00 B(ya)-0.36 C(xc)1.35 R81.50 D215.43 H130.20 P0.00
> 07:53:22.873 : echo
ID settings:
> 07:53:22.873 : echo: M301 P41.80 I3.75 D112.39
< 07:53:23.366 : N1 M110 *2
< 07:53:23.366 : N2 M115 *4
< 07:53:23.366 : N3 M111 S6 *68
> 07:53:26.298 : echo
D init fail
> 07:53:26.311 : ok
> 07:53:26.311 : ok
> 07:53:26.311 : FIRMWARE_NAME:Marlin V1; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[
< 07:53:26.311 : N4 M111 S6 *67
< 07:53:26.317 : N5 M80 *62
> 07:53:26.317 : ok
> 07:53:26.317 : ok
< 07:53:26.317 : N6 M105 *1
< 07:53:26.317 : N7 M220 S100 *70
> 07:53:26.330 : ok
> 07:53:26.330 : ok
> 07:53:26.330 : ok T:29.2 /0.0 B:18.6 /0.0 T0:29.2 /0.0 @:0 B@:0
< 07:53:26.330 : N8 M221 S100 *72
> 07:53:26.335 : ok
< 07:53:26.335 : N9 M111 S6 *78
> 07:53:26.346 : ok
> 07:53:26.346 : ok
< 07:53:26.477 : N10 M112 *48
> 07:53:26.490 : ok
> 07:53:28.866 : start
> 07:53:28.866 : echo: External Reset
> 07:53:28.866 : Marlin 1.0.0
> 07:53:28.866 : echo: Last Updated: Mar 20 2014 21:51:59 | Author: (SGraber, Cerberus Pup 170)
> 07:53:28.866 : Compiled: Mar 20 2014
> 07:53:28.866 : echo: Free Memory: 11512 PlannerBufferBytes: 1232
> 07:53:28.866 : echo
> 07:53:28.866 : echo
teps per unit:
> 07:53:28.866 : echo: M92 X160.00 Y160.00 Z160.00 E191.50
> 07:53:28.866 : echo:Maximum feedrates (mm/s):
> 07:53:28.866 : echo: M203 X150.00 Y150.00 Z150.00 E200.00
> 07:53:28.866 : echo:Maximum Acceleration (mm/s2):
> 07:53:28.866 : echo: M201 X9000 Y9000 Z9000 E9000
> 07:53:28.866 : echo:Acceleration: S=acceleration, T=retract acceleration
> 07:53:28.866 : echo: M204 S3000.00 T3000.00
> 07:53:28.866 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
> 07:53:28.866 : echo: M205 S0.00 T0.00 B20000 X20.00 Z20.00 E20.00
> 07:53:28.866 : echo:Home offset (mm):
> 07:53:28.866 : echo: M206 X0.00 Y0.00 Z0.00
> 07:53:28.866 : echo:Endstop adjustment (mm):
> 07:53:28.866 : echo: M666 X-1.24 Y-1.54 Z-1.97
> 07:53:28.866 : echo
> 07:53:28.866 : echo: M666 A(xa)0.00 B(ya)-0.36 C(xc)1.35 R81.50 D215.43 H130.20 P0.00
> 07:53:28.866 : echo
ID settings:
> 07:53:28.866 : echo: M301 P41.80 I3.75 D112.39
< 07:53:29.370 : N1 M110 *2
< 07:53:29.370 : N2 M115 *4
< 07:53:29.370 : N3 M111 S6 *68
