I am using a German Reprap x400 printer, controlling via repeater host. All I want to do is be able to change which extruder head I control to extrude or retract material into the machine.
shows the print panel and the drop down menu where I should be able to select either extruder 1 or extruder 2 but as you can see there is only one option..
shows the slicer panel and the slicer configuration window. As you can see I have added 2 extruders, and saved the profile. When I select that 2 extruder profile in repeater host I am unable to change the filament settings under extruder 2 and basically I can't get it to register that I have 2 extruders to control. I know this can work, I usually use an alternative laptop to control the printer and it is set up to work there, but this was done prior to my knowledge of the programs etc and I am unable to gain access to this laptop now. I have a feeling this is quite a simple fix but if anyone can make me feel stupid I would actually be very grateful!
Thanks
