Serial com error
Posted by bioenergy
Serial com error
July 18, 2014 04:59AM
I bought a new 3D printer cant get any support from the supplier. after I setup Repetier V0.90C and connect to the 3D printer. There is error message as following: "Serial com error: System.IO.Ports.SerialErrorReceivedEventArgs" I'm been running Win8 can anyone can help me for this solution. Thanks!
Eddy
Re: Serial com error
July 31, 2014 09:30PM
Can anyone help me for this IO error issue?
August 01, 2014 05:09AM
You can connect with the Ardiuno IDE and upload the firmware ok?
September 21, 2014 06:37AM
i have repetier and melzi, driver is ft232r usb uart but show error in com, could you help me what I have to do?
open | download - serialerror.jpg (19.7 KB)
September 22, 2014 09:15AM
This error message contains no information about your problem,
it is possible that there are multiple causes that trigger this error.
Lucastar fixed this error by changing the baudrate from 19200 to 76800 bps.
Does this also happen when you connect using the Arduino serial monitor?
Edited 1 time(s). Last edit at 09/22/2014 09:16AM by 3D-ES.
RS-Online Ormerod #263, Kossel mini with Minitronics, Prusa i3 MK2
November 17, 2014 09:37PM
i have the same error. luckily i have 2 laptop. one on win 7, one on win xp.
i try to install the printer on xp, and work ok.
i had error on win 7.
