I use the up to date repetier firmware from Github and my printer is ramps1.4 controlled delta(mini kossel). I'd like to try the sd_pause function during the printing, the printeris actually paused after run a few commands, and go to the wait postion. But after that I can't resume the printing with continue menu item. And Even wrose, all the data on SD card is corrupted. Don't know if other guys has the similar problem but be careful to use that functions. I enabled the FEATURE_MEMORY_POSITION feature, don't know if it relate with this.
Any suggestions? Thanks in advance!
BTW: the UI controller is Reprap discount controller.
Edited 1 time(s). Last edit at 08/01/2014 12:38PM by shaqiu.
