(I posted this in the firmware forum but haven't had any replies so I thought this might be a more appropriate audience)
I just upgraded my Repetier firmware to 0.92.
My hot end temperature reading is zero. I suspect this may be because I have my own thermistor table (from my previous configuration.h, so I know it works ok) but I have failed to correctly inform the firmware to use that table. I used to set it using "#define EXT1_TEMPSENSOR_TYPE 0" line in my previous firmware version.
I've copied that line (plus the thermistor table I defined) into configuration.h but am unsure if that has done the trick
Any advice?
Thanks
Pete
