Servo control with FW 0.91 on Sanguinololu
Posted by davejones
November 17, 2014 04:19AM
Compile error after enabling servo control.
HAL.cpp:584:2: error: #error No servo support for your board, please diable FEATURE_SERVO
Can this be fixed or will I have to change board or FW?.
Board is Sanguinololu 1.3a with ATMEGA1284 and FW is 0.91.
Intend to use pin 27 for servo.
Cheers,
Dave
Edited 2 time(s). Last edit at 11/17/2014 05:22AM by davejones.
Ordbot Hadron
Sanguinololu
Repetier Host
Repetier Firmware
Cura
Re: Servo control with FW 0.91 on Sanguinololu
November 17, 2014 07:36AM
You can try
#if 1 || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) || defined(__AVR_AT90USB646__) || defined(__AVR_AT90USB1286__) || defined(__AVR_ATmega128__) ||defined(__AVR_ATmega1281__)||defined(__AVR_ATmega2561__)
a but further in HAP.cpp where the cpus are tested. With some luck your cpu also has timer 3 whcih is used for servos, but I think it stops at timer2.
November 17, 2014 05:49PM
repetier
You can try
a but further in HAL.cpp where the cpus are tested. With some luck your cpu also has timer 3 whcih is used for servos, but I think it stops at timer2.
Working perfectly. Thank you.
Keep up the good work.
Cheers,
Dave
Edited 1 time(s). Last edit at 11/17/2014 05:50PM by davejones.
Ordbot Hadron
Sanguinololu
Repetier Host
Repetier Firmware
Cura
